about error
Old   March 1, 2006, 03:26
Default about error
erick
When I run my model in CFX-solver, I saw the followering notice:
" A wall has been placed at portion(s) of an outlet boundary condition ( at 39.3 % of the faces, 38 % of the area) to prevent fluid flowing into the domain. The boundary condition name is outlet1. the fluid name is air at 25℃. If this situation persists, consider switching to an opening type boundary condition instead. "
------------------------------------------------------ Could you give me some advice to solve my case.
The model is simple: a cuboid with two open end as outlet 1 and outlet 2, a hole in another surface is a inlet.
I use Extrude to creat the cuboid and the inlet hole(a little cylinder)
Old   March 1, 2006, 06:04
Default Re: about error
M
It means that the outlet is placed near an area of re-circulation. Either the flow from the INlet is not fast neough to reach the outlets or they are located in regions hwree the flow may be re-circulating. To avoid this you can use an Opening instaed of an outlet
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
user defined function cfduser CFX 0 April 29, 2006 11:58
