Fluid Structure Interaction using MFX : ANSYS-CFX
Old   March 1, 2006, 00:37
Default Fluid Structure Interaction using MFX : ANSYS-CFX
Manoj Kumar
Hi Everyone
Has anyone simulated fluid structure interection problem e.g. simulation of motion of a ship model in a wave tank, using MFX ? I was able to simulate flow around the shil hull in cfx very well (with out motion).The I thought of trying FSI. I have prepared two model, the ship hull in ansys and the fluid domain in cfx. When I try to start the simulation form ansys launcher (MFX -ANSYS/CFX environment) I get following error ..
/COM,ANSYS RELEASE 10.0 UP20050718 16:41:57 02/28/2006
*** FATAL *** CP = 0.953 TIME= 16:42:05
The database (-db) space requested is not currently available. Reenter ANSYS command line with less database space requested.
The above error is non-recoverable by ANSYS ANSYS run terminated by the indicated error Current data base saved if possible.
/COM,ANSYS RELEASE 10.0 UP20050718 09:52:58 03/01/2006
*** FATAL *** CP = 1.000 TIME= 09:53:29 Fatal error notification received The reported error is Process CFX
encountered the error: -11000.
Can anyone let me know what these errors are? Thanks in advance.
Manoj
Old   August 23, 2010, 16:20
Default The database (-db) space requested is not currently available.
souvik
souvikpravda is on a distinguished road
Go to customization/preferences on ansys product launcher window....check the use custom memory settings.....reduce the total workspace & database both....its a trial & error method...for me it worked....for 32 bit windows xp platform make total workspace 400 MB & database 150 MB....i think it will work!!!!!
souvikpravda is offline   Reply With Quote
Old   June 3, 2015, 08:41
Alberto Benitez Ruiz
Alberto_Benítez is on a distinguished road
Hi, everyone.
I´m triying to simulate a FSI using MFX. I obtained next error:
"Quadrilateral elements has negative or zero volume. Nodes on elements must be numbered counterclockwise"
Do you know how i can solve this problem?
Thanks.
Alberto.
Alberto_Benítez is offline   Reply With Quote
Fluid structure interaction. Haree FLUENT 2 August 7, 2010 03:56
Fluid structure interaction in Fluent Hari Prasad FLUENT 2 July 16, 2010 04:17
books on fluid structure interaction Li Main CFD Forum 0 January 18, 2008 11:02
Fluid Structure Interaction shaan Main CFD Forum 2 February 9, 2007 09:03
Fluid Structure Interaction pk Main CFD Forum 6 August 15, 2005 17:24
