November 18, 2019, 02:19 |
Mass Flow Rate is Not Conserved
nicola
Rep Power: 10 |
I have a problem with Pressure Inlet & Pressure Outlet condition.
At the inlet, cross section area is bigger and I have some mass flow rate. Further into downstream cross section gets smaller and mass flow rate also gets smaller, the difference is not small as well. Shouldn't it be conserved? |
November 18, 2019, 04:21 |
Rep Power: 144 |
Assuming a converged, steady state simulation with an inlet and an outlet, then yes the inlet and outlet flows will be the same. If yours does not then your simulation is not converged. Run it for more iterations.
November 18, 2019, 09:57 |
Rep Power: 33 |
In addition to Glenn's comments, how are you computing the mass flow? i.e. are you looking at solver computed values for mass flow? or are you computing the mass flow yourself?
boundary condition with pressure AND mass flow rate | tsi07 | FLUENT | 3 | April 14, 2022 12:32 |
Target Mass Flow Rate option for Pressure Outlet | Tianyi | STAR-CCM+ | 11 | October 23, 2019 06:56 |
Access inlet mass flow value (target mass flow rate) | YCarv | Fluent UDF and Scheme Programming | 2 | April 1, 2018 08:09 |
Mass flow rate boundary condition with negative values | hebe2u. | CFX | 1 | December 27, 2016 03:53 |
Higher mass flow rate at outlets as compare to inlet | Ahmed Saieed | FLUENT | 0 | April 3, 2016 23:08 |
