February 27, 2006, 07:15 |
ICEMCFD 2D Mesh limitation
I am trying to generate a simple planar 2D mesh in ICEM. (icemcfd 5.1-linux) I get an error message if i specify more than a certain number of points on one edge and the block is not meshed: A minor internal error has occurred. You may continue to work but if problems arise they may be related to this error. Try using the check/fix function to fix the problem The following message was designed to aid developers fix the problem: too many points in retrieve_face_info Is there a bugfix for this error? What is the check/fix function? |
February 27, 2006, 23:56 |
Re: ICEMCFD 2D Mesh limitation
I'm not sure but I suspect that could be sth related to the tolerance of your geometry. Is the mesh scale smaller than the tolerance you specify in geometry?
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 12:45 |
Importing an OpenFOAM mesh into Engrid. Is there a mesh size limitation ? | ayoros | enGrid | 0 | April 20, 2011 10:53 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 13:07 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
