Biphasic simulation (GVF 80%) - Overflow problems
Old   February 21, 2006, 11:22
Default Biphasic simulation (GVF 80%) - Overflow problems
Robbe
Hello, I´m trying to run a biphasic (water-air) simulation in a rotor with high percentage of gas (80%). I always get a fatal overflow message for the linear solver (with an F in the last column) after 50 iteractions aprox no matter what bondary condition I put and with automatic initial values.
I´m using a combination with total pressure and flow rate conditions (bulk mass or velocities or mass of each flow, etc..) in the inlet and outlet, and viceversa; ; a water bubble of 0.1 mm; a k-e turbulence model; a blend factor of 0 to get a initial value for a High resolution scheme; a Grace correlation...
I already simulated this rotor with monophasic flow and biphasic with 20% of GVF without problems.
If there is anyone that can give me advices for high gas fractions simulations, please let me know.
Thanks, Robbe
problems of turbo simulation in CFX-10 Qiang CFX 0 September 12, 2006 00:19
problems with unsteady spray simulation Mathias FLUENT 1 July 20, 2006 17:13
Transient simulation and sliding mesh problems alige FLUENT 0 May 8, 2006 04:51
problems simulation ideal gas, divergence in AMG S Ralf Schmidt FLUENT 11 October 1, 2005 14:21
Boundary layer simulation - convergence problems Gavin Tabor Main CFD Forum 3 July 2, 2004 06:16
