February 21, 2006, 06:29 |
Different Physical time steps selection
Hi All, I have one question regarding Physical time step selection. I want to use small physical time step for first few iterations and bigger time step after cetain no.of iterations in a single run. Is it possible to do like in Transient simulation?
Thank you. Regards, siv |
February 21, 2006, 10:03 |
Re: Different Physical time steps selection
Yes, simply type in a list of timesteps you want to use.
eg: 0.2 [s], 0.2 [s], 0.2 [s], 1.0 [s], 1.0 [s], ... I think there is a short form as well. 0.2*3 [s], 1.0 [s], ... |
February 21, 2006, 14:35 |
Hello Neale i want to use in steady state simulation not in transient simulation. In transient simulation its possible but i dont know how to define for steady state simulations.
February 22, 2006, 03:18 |
Hi, it is possible with CEL expression. Take a look at function "citern" in CFX help.
Best regards |
February 22, 2006, 10:55 |
The method Neale introduced works for both transient and steady state problems. Regards! Jianping |
February 23, 2006, 12:42 |
Or, you can Edit Run in Progress, by this way you can increase physical timestep whenever you feel you should do so (sure you need to be present to do this, ^_^)
Regards, Forrest |
Setting time step and number of time steps | milton.tafadzwa | FLUENT | 11 | March 24, 2018 10:41 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 05:35 |
Physical and Chemical time scale in dieselEngineFoam | arun | OpenFOAM Running, Solving & CFD | 0 | April 27, 2009 01:19 |
CHT. Cooled blade. Different time steps. | Georg | CFX | 4 | December 26, 2008 09:26 |
How many time steps should I use? | Dhananjay | FLUENT | 1 | July 19, 2002 10:20 |
