How to set the different Ref. Density in fluid domains? |
November 8, 2019, 07:52 |
Sumin Park
Rep Power: 7 |
hi all,
I want to set air and helium in two fluid domains respectively. Two fluid domains are separated by solid domain. But in cfx, in fluid domain, the fluid set automatically same. So, I found two method. a. Use "Enable Beta Features" b. Use Multi-component mixture The method "a" is unstable that i know, so i will use method "b". Q1) How can i set the properties about multi component mixture? Is it okay to just use "ideal mixture" option in transport, radiation(and so on..) properites? Q2) My case is in natural convection. So I want to set full buoyancy model in two fluid domains. How can i set the Ref. density? Use average density about air and He? or Is there a method to insert different Ref. density respectively? I will anticipate your answer... thank u. |
November 8, 2019, 08:51 |
Rep Power: 33 |
May I ask what is the problem with "Enable Beta Features"?
Did you untoggle the Constant Domain Physics? |
November 12, 2019, 02:10 |
#3 | |
Sumin Park
Rep Power: 7 |
first, I don't know exactly about function of that. Just I know that if i use the enable beta features, different fluids can set in two fluid domains respectively. But I heard that is unstable. So i didn't use that. second, actually i use the Constant domain physics in cfx - option - general. |
November 12, 2019, 04:15 |
Rep Power: 144 |
Enabling beta features means you are using features which are not fully tested, so could be inaccurate, unstable or misleading. They are recommended for advanced users who can spot when the solver is doing silly things. But used correctly they allow many extra features to be available. So it's your call about whether you use them or not.
cfx 14, multicomponent mixture |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Is 2-way FSI valve modeling with seperate fluid domains possible? | Maurosso | FLUENT | 4 | March 7, 2013 08:56 |
Seperate fluid domains | indgepr | CFX | 1 | February 28, 2012 04:36 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
