February 20, 2006, 17:20 |
Hi Mach drag prob
Hi, I am trying to baseline a technique for determining the drag of projectiles at high mach using cfx 10. To achieve this I have a reference projectile design with known drag at various mach numbers.
Thus far I have modelled it in several ways, the most recent using a symmetry plane running half way through the projectile. I have used a very fine mesh around the projectile, and a semi fine mesh in the rest of the domian. The entire domain is approx 30mm by 30mm by 40mm and contain approx 1.2 million elements. I have set the body to wall no slip, the inlet to supersonic with vel of 680.9 m/s total energy, the outlet to supersonic, and the surrounding walls to wall free slip. Fluid is set to air ideal gas. The initial values were set at 680.9 m/s and the K E turbulence model, with intensity to 5 or 10%. During the solve, I get warnings about max continuity loops to 2, what ever that means. It either solves with the wrong force, value is too low ( hence drag ) or it terminates with errors. Can anyone point me in the right direction as to what I am doing wrong? I have not used any inflation for my cfx mesh as I do not fully understand it. Could it be a mesh problem or am I just setting my solver parameters wrong? I can email my files if anyone wants to have a look at them. Any help would be appreciated. Stuman |
February 24, 2006, 09:03 |
Re: Hi Mach drag prob
In case of supersonic flow we always use
EXPERT PARAMETERS: max continuity loops = 2 END works every time! |
February 26, 2006, 05:06 |
Yeah I eventually found that and added mesh adaptation as well, now it does not crash but it only gets within 10% of the actual drag value. I think my problems lies in the mesh now.
Thanks for your response Stuman |
Pressure drag, friction drag and total drag? | Cheng | CFX | 9 | January 26, 2024 13:46 |
Drag Force on Axisymmetric Cone in Mach 5 Flow | SleeperService | FLUENT | 0 | February 28, 2011 00:56 |
anyone has got this paper? | Al | Main CFD Forum | 3 | October 8, 2007 02:04 |
non-dimensional analysis in Fluent | Endee | FLUENT | 8 | September 7, 2005 16:16 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
