Referencing angular velocity in a CEL expression
Old   November 7, 2019, 18:07
Default Referencing angular velocity in a CEL expression
Nick Thomas
nick.l.thomas is on a distinguished road
I would like to create an expression that references the angular velocity of a rotating domain within a stationary domain. I've tried and understand that I can't average it like a field variable at a particular domain or boundary. Similarly I would like to create an expression that uses inlet velocity as a variable. At the moment I am just doing that by
areaAve(Velocity)@Inlet
but is there a better way that simply references the exact value specified at the inlet?
nick.l.thomas is offline   Reply With Quote
Old   November 7, 2019, 23:50
Define a CEL variable for the rotational speed and use that to set the rotational speed. Then you can refer to the CEL variable where ever you like.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
cel expression
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 09:56
Accessing parcel angular velocity from particel force class slint OpenFOAM Programming & Development 1 September 27, 2016 13:46
CEL expression in CFX pre Jane92 Main CFD Forum 1 June 3, 2016 03:48
Turbine Angular Velocity Problem mechkween CFX 5 May 18, 2016 23:40
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
