RTD in reactor
Old   February 14, 2006, 07:43
Default RTD in reactor
user
hello
i want to do RTD studies on reactor for that i have a created an Additional Variable "RDT" with unit [s]and volumetric vaiable type . RDT is set "0" at all inlet.
Then create a subdomain "RDT sub" over all and impement a source for RTD with 1 [s/s].
my question is how do to see residence time distribution in CFX post and how will we get RTD curve
with regards user
Old   February 14, 2006, 14:30
Default Re: RTD in reactor
Jianping Zhang
Similer as doing experiment, you need to input tracer('RDT' as you created) (either step or pulse input) from inlet and monitor the change of concentrations at outlet. You will see the RTD curve in solver monitoring window.
The steady state solution as you described will not give you a tracer curve.
Search 'tracer' in official CFX forum, you will find more detailed information.
Regards!
Jianping
Old   February 15, 2006, 09:49
user
hello zhang
thanks for suggestions,now i got RTD curve is it possible to get dispersion coefficient from residence time distribution
can u guide me How to get dispersion coeffiecient from RTD study
thanks in advance with regards
Old   February 15, 2006, 13:25
Jianping Zhang
I do not have experience of doing that, however I think you have to have some experiemntal RTD curves(for validation purpose) as well for calculating dispersion coefficient.
To calculate dispersion coefficient, I believe you can easily find examples in most of reactor theory books.
Regards!
Jianping
Old   February 16, 2006, 00:40
user
hi zhang
best regards
Old   February 21, 2006, 08:41
Default Query : RTD in reactor
Jayadeep.K
Hello friend,
I am a student of M.E chemical engineering, BITS-Pilani, INDIA. I am working on RTD prediction in an ideal plug flow reactor using fluent. I don't know how to inject tracer in CFD. I would be grateful to you if you can help me in this regard.
These are the inputs I have given. Are these specifications correct?
Models-viscous-laminar. 2-D unsteady state, implicit formulation. Length of PFR=50 cm. Diameter=5 cm. Materials inside the reactor=Water, Toulene. Tracer used: Toulene. Mass flow inlet of toluene=0.023 kg/s. Mass flow inlet of water=0.039 kg/s. X-velocity of tracer=0.0135 m/s. Delta t=1 s. Total no. of time steps=840 s.
I would be very much grateful to you Jianping Zhang if you can help me in this regard. Please send the procedure of predicting RTD in Fluent if you can.Also is there any provision of concentartion input in fluent?
Awaiting for your earliest reply, Jayadeep.
Old   February 21, 2006, 11:00
Default Re: Query : RTD in reactor
Jianping Zhang
To model tracer RTD, usually you define tracer(Toulene?) as a scalar instead of as a component.
I do not use fluent. The following post may be useful for you.
http://www.cfd-online.com/Forum/flue....cgi/read/6677
regards!
Jianping
ScalarTransportFoam for RTD calculations santoo_cfd OpenFOAM Running, Solving & CFD 39 July 12, 2021 02:15
transient result in spray reactor with swirl flow glenn creten Main CFD Forum 1 August 14, 2012 06:10
Phosphoric acid reactor model N.Ramakrishnan Main CFD Forum 0 July 29, 2004 07:38
Passive cooling system for batch reactor Darek Main CFD Forum 0 September 30, 2003 06:06
RTD is single phase system in Kenics Mixer vaibhav IIT Delhi FLUENT 0 October 17, 2002 15:05
