Parallel Computing help for a newbie
Old   February 12, 2006, 14:34
Default Parallel Computing help for a newbie
Bill
A friend of mine would like to set up a cluster to speed up graphics rendering. He has two old computers at present, both single core pIII 1Ghz machines running on a 10/100 broadband router. Can anyone suggest hardware/software I might need to obtain to help out? Thanks
Old   February 12, 2006, 17:17
Default Re: Parallel Computing help for a newbie
Parallel software rendering has little to do with CFX. I think you are posting on the wrong forum.
unchangeable continuity residuals in parallel computing wlt_1985 FLUENT 0 August 1, 2011 13:15
Diffusion equation solved using Parallel Computing Sachin Paramane Main CFD Forum 0 June 12, 2007 00:48
Parallel Computing on Multi-Core Processors Upgrading Hardware CFX 6 June 7, 2007 16:54
Parallel Computing peter Main CFD Forum 7 May 15, 2006 10:53
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
