How to distribute no. of CPUs among parallel jobs?
Old   February 9, 2006, 04:46
Default How to distribute no. of CPUs among parallel jobs?
SGI Altix
Hello guys..... I'm a bit confused about how to make full use of the CFX license that we have for the current job. We have 4 parallel licenses, 4 unlimited licenses and 20 limited licenses in the server. Our gear is SGI machine that consists of 32 itanium Pentium chips. From my understanding, when running a parallel job, we need to assign 1 license for each CPU.
My problem currently used about 1.3million nodes. Should I assign more CPUs for each job to reduce no. of nodes per partition so that I can use limited licenses for the run as well?
Thank you for your inputs here.
Old   February 9, 2006, 17:49
Default Re: How to distribute no. of CPUs among parallel j
Why don't you just try it and find out? It will probably work nicely.
Old   February 11, 2006, 22:30
Jeff
To run a parallel job, you need a single acfx_solver, a single acfx_parallel license, and one acfx_par_proc for each partition including the master. Look at how many par_proc licenses you have, that will determine how many partitions you can use.
Jeff
Old   February 14, 2006, 02:38
SGI Altix
Thanks, Jeff. You catch my question. It's actually the par_proc that limits the amount of CPUs that I can assign for a parallel job. I have 8 par_proc licenses in the server.
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 23:51
Parallel Jobs Zaktatir CFX 7 January 25, 2011 06:22
multiple parallel jobs on one machine joeybernard CFX 0 December 16, 2010 11:10
Parallel Fluent: trouble going from 2 to 4 CPUs Mario FLUENT 6 August 24, 2006 01:17
running multiple Fluent parallel jobs Michael Bo Hansen FLUENT 8 June 7, 2006 09:52
