2 BC's on same surface
Old   February 8, 2006, 05:25
Default 2 BC's on same surface
shyam
Hi, I am dealing with a multiphase eulerian and eulerian problem, where i need to specify same surface as inlet for componet A and outlet for componet B. How to do it? Thanks in advance
shyam
Old   February 8, 2006, 10:11
Default Re: 2 BC's on same surface
panneerselvam
Hi shyam
if u need to specify velocity for both components on the same surface of the inlet , then u have to specify the volume fraction of each components , for eg u know the superficial velocity of the both componets , then specify the average velocity in inlet ie avg vel of componet A= super. vel. of comp. A/ volume fraction of comp.A volume fraction of comp A= super.vel. of comp. A/(super.vel. of comp. A+super.vel. of comp. B)
with regards panneerselvam
Old   February 9, 2006, 07:27
shyam
Thanks for your interest, I understand that what you suggested is for two inlets for different componets. But I have to send one componet into the domain and the other, out of the domain at specified flow rates on the same surface. Thanks in advance
Old   February 9, 2006, 08:22
TB
Is this a steady flow problem? Specifying velocity profile with opposite direction may be workable. I'll normally break the surface into two parts during the meshing stage.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
