Run-Time memory conifguration Error
Old   February 8, 2006, 02:22
Default Run-Time memory conifguration Error
Graeme
I am getting a memory config error when I try to run my simulation.
Basically I require: Real: 998,000 Kbytes, Integer: 285,000 Kbytes, The rest: 10,000Kbytes
And yet I have 2Gbytes? If I go into Task Manager and check available memory, I have 1,580,000 K available physical memory, so the solver should run. Other simulations do work, including one for only 200Mb less.
Sorry about the below formatting, but this is the specific error generated by solver (CFX 5.7)
+--------------------------------------------------------------------+ | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+
Data Type Kwords Words/Node Words/Elem Kbytes Bytes/Node
Real 255592.7 599.40 130.18 998408.8 2397.60 Integer 72907.1 170.98 37.13 284793.2 683.91 Character 2203.7 5.17 1.12 2152.0 5.17 Logical 40.0 0.09 0.02 156.2 0.38 Double 908.0 2.13 0.46 7093.8 17.04
+--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | *** Run-time memory configuration error *** | | Not enough free memory is currently available on the system. | | Could not allocate requested memory - exiting! | | | | | | | +--------------------------------------------------------------------+
Old   February 21, 2006, 00:04
Default Re: Run-Time memory conifguration Error
Graeme
I called Ansys support and after a few days of them thinking, the problem is now fixed. Just in case anyone has the same problem in the future, I'll give the solution to the problem:
It's a windows problem. Whilst the computer has enough memory to run the simulation, it does not have enough in a continuous block. Therefore I needed to set up a PVM Local Parallel distribution (might require licences?). This partitions the solving into seperate chunks of a certain memory size each and hopefully the computer can find free momory eaual to the size of these chunks. This step is done in solver at the define run stage.
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 06:17
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
