Inlet flow angle without specifying velocity components |
October 14, 2019, 07:03 |
Rep Power: 7 |
Hello everyone,
is it possible to define a flow angle at an inlet without specifying the velocity components of the flow vector? I am using pressure inlet but I also need to specify the angle. I appreciate your help. Best regards! |
October 14, 2019, 09:21 |
Rep Power: 33 |
Which angle do you have?, i.e. angle respect to which axis?
The velocity components are the cosine of the angle respect to the axis, i.e. those are the angles you have |
October 14, 2019, 11:11 |
Rep Power: 7 |
I want to set an inlet angle of 30° wrt the x-axis.
But I can't specify the inlet velocity components, because the inlet velcoity is part of the solution and not of the boundary conditions. I only define the inlet total pressure. |
October 14, 2019, 11:22 |
Carlo_P
Rep Power: 8 |
Yes.
You have to set up a coordinate axis. Then, you can use cylindrical component - axial component using the coordinate axis you define before. This should work. Let me know. Thanks! |
October 14, 2019, 16:15 |
#5 | |
Rep Power: 33 |
I think you are confusing the direction velocity vector with the velocity vector itself for the subsonic setup combining Total Pressure + Flow Direction Velocity Vector = Velocity Magnitude * Direction Velocity Vector = Velocity Magniture * (Unit X, Unit Y, Unit Z) Are you referring to the Unit Vector Component X/Y/Z components? or the Cartesian Velocity Components? |
October 15, 2019, 02:08 |
M
Rep Power: 13 |
Perhaps you can make a slight change to the geometry to incorporate a chamfer of the desired angle and specify total pressure there? Not an elegant solution, but might be possible, depending on how big the inlet is compared to the rest of the model.
angle, cfx, inlet |
kindly help me .. i have and error at line number 147.. | m zubair | Fluent UDF and Scheme Programming | 0 | February 10, 2019 12:25 |
[swak4Foam] Inlet velocity profile for turbulent pipe flow using swak4Foam | zordiack | OpenFOAM Community Contributions | 5 | February 23, 2016 02:52 |
3-D parabolic velocity Inlet - Steady state - UDF Turbulent Flow | mohibanwar | Fluent UDF and Scheme Programming | 10 | May 18, 2015 11:34 |
How to define a fixed velocity for a given mass flow rate on inlet | mqasimali | FLUENT | 2 | April 12, 2013 18:24 |
Do Pressure Inlet Flow Direction Components Need to Be Normalized? | ScottN | FLUENT | 0 | September 21, 2010 10:18 |
