NASA Format
Old   February 4, 2006, 10:27
Default NASA Format
Stone
Is there a way to create a liquid material with specific heat capacity in NASA Format? Normally NASA Format is only useable for gases but I in the CFX Folders there is a .CCL with the properties of a liquid with NASA Format cp. Why should CFX create this, when it is not useable?
Old   February 7, 2006, 03:48
Default Re: NASA Format
Neale
This is a bug.
Pre complains, but it will run in the flow solver.
If you need to create a new material set the state to gas, type in the coefficients and then switch the state back after hitting apply. Pre will complain, but it will run.
Old   February 7, 2006, 11:17
Stone
Thank you very much Neale.
Old   August 11, 2021, 03:16
Arif Aziz
Arif Aziz is on a distinguished road
How to calculate and type these NASA coefficient
Arif Aziz is offline   Reply With Quote
NASA format Cujo CFX 9 August 12, 2021 09:50
NASA FORMAT - AIR cynthia CFX 6 November 15, 2011 08:20
Best format for simulation data? cbisw Main CFD Forum 9 May 30, 2011 03:38
Nasa Rotor 67 points in X-Y-Z format t_shirt Main CFD Forum 0 June 15, 2010 15:39
How to Read Nasa Format Stone CFX 6 March 20, 2006 03:03
