help for CFX solver
Old   February 3, 2006, 04:36
Default help for CFX solver
richard
I got this error messenge while running the solver. Pls help. Any suggestion is welcome.
ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | *** Run-time memory configuration error *** | | Not enough free memory is currently available on the system. | | Could not allocate requested memory - exiting! | |
Old   February 3, 2006, 05:46
Default Re: help for CFX solver
TB
The message is quite clear, isn't it? It means that you have insufficient memory in your machine to run your problem.
Change memory allocation factor Default value in Solver to higher value e.g 1.1 or 1.2. If problems still exist, consider upgrading your hardware or reduce the size of your meshes (just for initial run).
Do a quick search for previous post in the forum. Plenty of tips for such problem.
Old   February 7, 2006, 02:08
Sarcasm Detector
TB,
Why do you feel the need to be sarcastic? I've read a few of your posts, and I think your attitude is uncalled for. If you are annoyed by the posters, go elsewhere.
Old   February 7, 2006, 18:31
It did not look sarcastic to me. I think TB's post was sensible and helpful.
Old   February 7, 2006, 23:23
TB
Hi.... You're a bit sensitive. I find a lot of useful information by doing some search over previous posts and it saves me time. I know some guys here aren't aware of this search feature. Nothing wrong about pointing this out.
A New Solver for Supersonic Combustion nakul OpenFOAM Announcements from Other Sources 19 February 27, 2024 10:44
[Other] A New Solver for Supersonic Combustion nakul OpenFOAM Community Contributions 20 February 22, 2019 10:08
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
Development of a Low mach PISO solver nishant_hull OpenFOAM Programming & Development 0 August 25, 2009 13:48
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
