Cylindrical coordinates in Vector Algebraic Equation in CFX |
October 1, 2019, 22:43 |
Qazi Shahzad Ali
Rep Power: 8 |
I have Axial force (Fn) and Tangential force (Ft) components in cylindrical coordinates. I want them to implement as an Additional Variables in terms of Vector Algebraic Equation in the rotating domain.
The Fluid Models Tab (Fig attached) of domain only shows (Vector xValue, Vector yValue, Vector zValue), do I have to first transform these components into Cartesian coordinates or there some other way to directly use them? |
October 7, 2019, 19:52 |
Rep Power: 144 |
The dialog box clearly wants xyz components, so you need to specify cartesian components.
Note you can also do this by defining a source term.
October 8, 2019, 08:49 |
Qazi Shahzad Ali
Rep Power: 8 |
Thanks Glenn,
Your expert advice made my day. Now its working perfectly. Actually, I was simulating “Actuator Disk model” in CFX, where I was declaring the CEL variables as Additional variable (AV) of CEL expressions and also including in sub-domain as source term. Now it’s clear to me that only just use sub-domain and make direct link to expressions (Force/volume) as a source. |
Unsteady Cylindrical heat equation with no source | abhi084 | Main CFD Forum | 6 | July 9, 2016 03:37 |
SIMPLE algorithm in 3D cylindrical coordinates | zouchu | Main CFD Forum | 1 | January 20, 2014 18:02 |
[mesh manipulation] Mapping mesh from cartesian coordinates to cylindrical coordinates | matteo_pellegri | OpenFOAM Meshing & Mesh Conversion | 0 | December 10, 2013 11:31 |
Cylindrical coordinates | Nish | CFX | 1 | May 3, 2000 04:01 |
Calculation in cylindrical coordinates | Franz Wingelhofer | CFX | 0 | December 28, 1999 08:46 |
