a problem in rotor-stator interaction (help)!
Old   January 26, 2006, 11:56
Default a problem in rotor-stator interaction (help)!
feng
I am simulating the impeller-diffuser interactions including an impeller, an vaned diffuser and an vaned return chnnel of a radial hydraulic pump. For the transient process, I set some monitor points in different regions to judge the flow periodicity. I found that for the pressure field, it gets periodicity very fast. But the velocity field is far from being periodic. The calculation has been running for dozens of impeller revolutions. The boundary conditions are total pressure at the inlet and mass flow at the outlet. Who can give me some advices? thanks a lot!!
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
