January 25, 2006, 08:13 |
Solver fails with compressible flow
Hi! I use CFX 10 with the option of compressible flow. So I set my density as a function of the pressure. My first question is: can I set the density with something else than "pabs" (p, solver pressure...?). And then, the solver fails when I use a formula of the form rho=f(pabs^2,pabs) and doesn't with a formula of the form rho=f(pabs). Doesn't someone knows why?? Thanks,
Eric |
January 29, 2006, 17:26 |
Re: Solver fails with compressible flow
Does it diverge or some other error? Getting a converged solution with an exotic equation of state (EOS) is difficult, you will need very small timesteps. Glenn Horrocks |
January 30, 2006, 10:02 |
Hi Glenn,
I got a convergence when I set a linear law for the density. But when I set a parabolic law, it diverges first with those kind of error message: | ****** Notice ****** | | While evaluating Static Enthalpy, | | Static Pressure on boundary upwall | | went outside of its upper limit. Its maximum value was | | 8.6234E+20. The bounds error was handled by clipping. | | If this situation persists, consider increasing the table range. And then it fails with this error message: | ERROR #004100018 has occurred in subroutine FINMES. | | Message: | | Fatal overflow in linear solver. I tried to increase the table range but it's still the same... Do you (or someone alse) have some advise for me to avoid that? Regards, Eric |
January 30, 2006, 17:05 |
The root of the problem is almost certainly to do with the enthalpy/pressure error first mentioned. Sounds like the simulation is diverging. Do a run and stop it before it crashes and have a look in CFX-Post. You will probably find a region of flow which is producing rediculous results and that will be source of the problem. Glenn Horrocks |
February 4, 2006, 08:28 |
Eric,
If you are using a CEL or User FORTRAN for the equation of state the flow solver internally generates tables for h(T,p) and s(T,p). One thing to make sure is that the table generation limits match what you expect to happen for your case. The default limits are 0.01 bar to 10 bar and 100 to 5000 K. Neale |
Solver for an incompressible, turbulent flow with heat transfer | tH3f0rC3 | OpenFOAM Running, Solving & CFD | 9 | June 17, 2019 06:12 |
compressible flow calculation error using rhoSimpleFoam solver | student4326 | OpenFOAM Running, Solving & CFD | 7 | November 2, 2015 11:34 |
help with compressible flow BC's (need subsonic flow) | meangreen | Main CFD Forum | 5 | July 24, 2010 13:16 |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM | 0 | April 4, 2010 18:06 |
low speed compressible flow | lily | CFX | 2 | November 16, 2005 05:15 |
