Supersonic diffuser flow - Shock system
Old   September 23, 2019, 23:56
Default Supersonic diffuser flow - Shock system
cyln
cyln is on a distinguished road
I am simulating a steady 3D supersonic-diffuser flow with CFX. The supersonic diffuser has a test section upstream with M=4. Inlet BC is set to Ptot = 8.3 bars, Outlet is set to P_static = 1 bar. I expect to have a shock termination somewhere downstream of the diffuser throat.
k-omega SST turbulence model is used for turbulence closure.
When CFX starts to capture the shock system, there is flow separation downstream of the shock system and I am not sure whether it is real or not. the total pressure downstream of the shock system falls below 1 bar (about 0.5 bar). Since this is less that the outlet pressure, the solver places a wall at the outlet to avoid inflow from the outlet. This way, mass is not conserved and this leads to unstarting (The shock system moves upstream of the throat).
Is there anyone who has dealt with this problem? Which turbulence model is ideal for such a flow? Any other way to treat the outlet?
Cheers,
Cyln
cyln is offline   Reply With Quote
Old   September 24, 2019, 03:41
Gert-Jan
Gert-Jan will become famous soon enough
This is a very common phenomena. You have to place your outlet further downstream.
Gert-Jan is offline   Reply With Quote
Old   September 28, 2019, 19:35
cyln
I tried placing the outlet way downstream, however, it did not make any change. It unstarts itself (the shock moves upstream of the throat). I tried three different theoretically correct geometric settings, still same result.
Is there any paper/reference that modelled a supersonic diffuser using CFX? Or anybody who did that successfully?
Cheers
Supersonic Flow Modeling - internal mahbood FLUENT 0 October 25, 2016 18:59
[How to obtain supersonic flow inside a supersonic wind tunnel ?] yx213 Siemens 1 September 17, 2014 14:52
Supersonic flow over an airfoil. FLUENT Lift don't match up with Shock Expansion Tech enriccasas FLUENT 1 August 21, 2013 07:43
Nozzle Flow with shock jim clancy FLUENT 1 December 18, 2001 05:19
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
