Error while compiling Fortran routine
Old   January 24, 2006, 04:39
Default Error while compiling Fortran routine
Manoj Kumar
Hi Everyone
I am getting following error, while trying to create shared library for the user sub routine, MomentumSource1.F used in one of the Ansys CFX 10 tutorials ...
C:\cfx\test1>cfx5mkext MomentumSource1.F
df -MD -fpp:-m -include:"C:\Program Files\Ansys Inc\CFX\CFX-10.0\include" -object:winnt\\MomentumSource1.o -c MomentumSource1.F
DIGITAL Visual Fortran Optimizing Compiler Version: V5.0
Copyright (c) 1997 Digital Equipment Corp. All rights reserved.
Digital (R) Fortran Preprocessor Version V5.0-007
Copyright (c) Digital Equipment Corp 1993,1997.
** error UNREC: Unrecognized option '-m'.
C:\DOCUME~1\Guest\LOCALS~1\Temp\fpp10.tmp
df -threads -dll:.\winnt\\MomentumSource1.dll
winnt\\MomentumSource1.o C:\Progra m Files\Ansys Inc\CFX\CFX-10.0\lib\winnt\solver-pvm.lib
Microsoft (R) 32-Bit Incremental Linker Version 5.00.7022
Copyright (C) Microsoft Corp 1992-1997. All rights reserved.
/entry:_DllMainCRTStartup@12
/ignore:505
/debugtype:cv
/debug:minimal
/pdb:none
"C:\Program Files\Ansys Inc\CFX\CFX-10.0\lib\winnt\solver-pvm.lib"
dformd.lib
msvcrt.lib
dfconsol.lib
kernel32.lib
/out:.\winnt\\MomentumSource1.dll /dll
LINK : fatal error LNK1181: cannot open input file "dformd.lib"
An error has occurred in cfx5mkext:
df exited with return code 73.
I went through the older posts but couldn't get much out of them. Can anyone help me out. Thanks in advance.
Manoj
Old   January 24, 2006, 05:30
Default Re: Error while compiling Fortran routine
TobiasZ
I guess you use a windows platform? The manual says that for this case Compaq Visual Fortran 6.5 or later is required and sucessfully tested.
Perhaps your compiler is not suitable for CFX-10. You could also try to use the command " ! system ("cfx5mkext <name_of_routine>.F") == 0 or die; " in CFX-Pre under Tools>CommandEditor. Another reason can also be that spaces are not allowed in the file name.
Hope this helps.
TobiasZ
Old   January 24, 2006, 23:59
selvam R.P
Hi all,
i am also getting same error while compiling in command line
df -MD -fpp:-m -include:\CFX\CFX-10.0\include -object:winnt\\CDvar_Coeff.o -c CDvar_Coeff.F Compaq Visual Fortran Optimizing Compiler Version 6.6 Copyright 2001 Compaq Computer Corp. All rights reserved.
Compaq (R) Fortran Preprocessor Version 6.6-24 Copyright 2001 Compaq Computer Corporation.
CDvar_Coeff.i df -threads -dll:.\winnt\\CDvar_Coeff.dll winnt\\CDvar_Coeff.o D:\CFX\CFX-10.0\l ib\winnt\solver-pvm.lib Compaq Visual Fortran Optimizing Compiler Version 6.6 Copyright 2001 Compaq Computer Corp. All rights reserved.
Microsoft (R) Incremental Linker Version 6.00.8447 Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
/entry:_DllMainCRTStartup@12 /ignore:505 /debugtype:cv /debug:minimal /pdb:none winnt\\CDvar_Coeff.o D:\CFX\CFX-10.0\lib\winnt\solver-pvm.lib dformd.lib msvcrt.lib dfconsol.lib dfport.lib kernel32.lib /out:.\winnt\\CDvar_Coeff.dll /dll Creating library .\winnt\\CDvar_Coeff.lib and object .\winnt\\CDvar_Coeff.exp
CDvar_Coeff.o : error LNK2001: unresolved external symbol _CDVAR_COEFF_CORE@52 .\winnt\\CDvar_Coeff.dll : fatal error LNK1120: 1 unresolved externals An error has occurred in cfx5mkext:
df exited with return code 96.
thanks with regards
Old   January 25, 2006, 05:08
TobiasZ
Hi Selvam,
I am not an expert, but I think your case is different. You have an error in your routine. During the compilation the compiler proofs, if your routine is correct and stops when an error occurs. It seems that you didn't define your external variable.
Regards
TobaisZ
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Error occurs when compiling Fortran in CFX-4.4 zhaoyangly259 CFX 1 June 9, 2010 07:28
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
FORTRAN Routine - variable passing Malcolm CFX 1 August 11, 2005 19:51
