Distributed parallel runs on ANSYS CFX 10
Old   January 24, 2006, 00:52
Default Distributed parallel runs on ANSYS CFX 10
Manoj Kumar
Hi Everyone
Is it a must to have ANSYS CFX 10 installed on all the machine when we want to run distributed parallel runs?
Thanks in advance.
Manoj
Old   January 24, 2006, 08:17
Default Re: Distributed parallel runs on ANSYS CFX 10
M
I tried to run a distributed parallel case but kept getting errors because one machine was using ansysy 10.0 and the the other with ansys 10.0 with service pack 1. When i installed the service pack on both the run worked fine.
Old   January 24, 2006, 09:08
longbow
If you are using Unix/Linux machines, you don't need to have CFX10 installed on all your machines. Install CFX10 on one machine and export installation directory as NFS mount point to other machines. Using this method can solve the inconsistent problem you mentioned above.
Old   January 24, 2006, 22:38
TB
M: a quick question for you. Are you sure there's a service pack for CFX 10? I browse the CFX community webpage but can only find service pack for CFX 5.7.1.
Old   January 25, 2006, 09:00
longbow
Yes. There is a sesrvice pack for CFX-10. You can download it from ANSYS customer portal.
Compressible Flow in Ansys CFX bcheruk CFX 15 July 6, 2017 07:30
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Ansys 13 CFX problem on LInux Opensuse 11.4 serendipity CFX 10 August 7, 2012 04:24
Ansys CFX bucket problem njsavage Main CFD Forum 1 April 30, 2009 10:48
Temperature transferring from CFX to ANSYS? Se-Hee CFX 0 November 28, 2006 06:56
