CFX 10 User Sub Routine
Old   January 17, 2006, 12:37
Default CFX 10 User Sub Routine
Claudia
I try to use a user sub routine in CFX10. The same routine works in CFX5.7.1 very well. When I try to solve the problem there is an error message like: Error opening C:\Programme\Ansys Inc\CFX\Shared\winnt\hollowa.dll: Das angegebene Modul wurde nicht gefunden. (He can't find it). But I'am sure that the sub routine is in this folder. The same path in cfx5.7.1 an it works. Some ideas?
Regards
Claudia
Old   January 18, 2006, 03:11
Default Re: CFX 10 User Sub Routine
TB
Are you using the same definition file from 5.7.1? Try redefining this subroutine again and write a new definition file.
Old   January 18, 2006, 04:07
Claudia
No, I am using a definition file from cfx10 but the entries belonging to the subroutine are still the same (copy & paste).
Old   January 21, 2006, 13:51
Jeff
Redefine a subroutine, even a false one, through CFX-10 pre, and then examine the resulting CCL. The CCL syntax for defining the routine may have changed from one version to the next.
Jeff
Old   January 23, 2006, 14:10
Claudia
Thanks, but I found the problem with the help of the support. My routines work in mpich an after the installation of CFX 10 I had to add a path in the microsoft environmental variables. The problem was not, that the routines were not there but that the solver path was missing. So he couldn't find the routines because the path of the solver was wrong. I had something like that also with CFX 5.7.1 but there the error was clearly indidcated.
Old   February 11, 2006, 05:54
JS
I think I have the same problem... I'd be glad to know where the path exactly should point.
Old   February 15, 2006, 09:32
Claudia
In my case I had to add the following path: C:\Program Files\Ansys Inc\CFX\CFX-10.0\bin\winnt. It has to be added in the windows environmental variables as the last entry of the list. The path should be the one where you can find the solver-mpichnt.exe and the solver-pvm.exe
Hope it can help.
User surface creation in CFX post Vicky88 CFX 3 January 28, 2011 06:34
Particle User Source in ANSYS CFX Jun CFX 0 September 8, 2010 10:28
how to implement an user defined equation of state in CFX 10.0 IvanCFD CFX 1 August 16, 2009 09:28
user defined function cfduser CFX 0 April 29, 2006 11:58
CFX User Subroutine Archive David Creech Main CFD Forum 0 March 17, 1999 13:41
