Using results form previous run as inlet condition
Old   January 16, 2006, 10:44
Default Using results form previous run as inlet condition
M
Hi All,
I would like to know how i can use the velocity profile at an outlet of a simulation which i have already ran as the inlet condition on another simulation. The geometry of the outlet in the original case is exactly the same as the inlet on the second case. Can anyone please help,
Thanks
M
Old   January 16, 2006, 22:19
Default Re: Using results form previous run as inlet condi
jemteo
If i'm not wrong, someone correct me if i am, under CFX5solve...under initial values...and select the your outlet results
Old   January 16, 2006, 23:43
TB
1. Export outlet velocity profile to a csv file in post.
2. Initialise this profile data in pre & use it for your boundary condition.
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 17:32
pulsating inlet boundary condition Jason CFX 1 July 29, 2004 12:47
inlet and outlet boundary condition of pump Thammasak CFX 0 February 9, 2004 14:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
