Moving Mesh with GGI
Old   January 16, 2006, 09:34
Default Moving Mesh with GGI
KBanks
Hi, does anyone know if it is possible to perform a moving mesh simulation using a Junction Box routine with a grid containing a GGI in CFX-10? The mesh deformation I require cannot be achieved using the standard method, hence the use of the Junction Box.
Old   January 16, 2006, 17:11
Default Re: Moving Mesh with GGI
You should be able to do this. I have not done it but cannot see a reason why it should not work.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 24, 2010 00:53
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
