September 6, 2019, 07:56 |
Particle Tracking ANSYS CFX
Drin Marmullaku
Hello Guys,
I'm simulating with CFX a accelerated air flow in a pipe and I'm also adding particles at some points at the beginning of the pipe. I'm using the Particle Transport Fluid Model, one-coupled, steady-state and the particles have a inlet velocity of about zero. My Problem is: When the particles are tracked, they get immediately the velocity of the surrounding gas flow. But this is not physically correct. They can't accelerate that fast. Below you can find a chart where you can see the velocity profile of the particle through the pipe. The injection of the particle is done with: Point Cone, Cone Angle = 2°C, Particle-Velocity = 0,0001m/s, Particle-Massflow = 8.2*10^-8 Can you help me? |
September 7, 2019, 08:11 |
Rep Power: 144 |
If you need more resolution in the start up acceleration then put a finer mesh there.
The solver is simply saying that given the conditions at the start of injection the particles will accelerate that much in their first integration step. So an alternative approach is to increase the number of integration steps.
September 8, 2019, 15:50 |
Gert-Jan
Rep Power: 28 |
It also depends on the drag relation, particle diameter, etc. What did you specify?
cfx, euler-lagrange, particle, particle track |
Particle tracking file per time step in an Unsteady Particle Tracking | Manu4CFD | FLUENT | 1 | December 29, 2022 08:15 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 06:31 |
Implementing Level Set Method in ANSYS CFX for Interface Tracking | a.sarami@yahoo.com | CFX | 3 | January 28, 2015 17:58 |
Count leaving particles through an outlet (with particle tracking method in CFX) | dygysl | CFX | 2 | October 29, 2014 08:30 |
Lagrangian Particle Tracking model In CFX | Kushagra | CFX | 8 | December 2, 2010 22:18 |
