CFX runs return no results
Old   September 5, 2019, 03:19
Question CFX runs return no results
Upeka
residual is on a distinguished road
Helo All,
I have been running a cfd in CFX for a fan case. the mesh for volute and impeller are generated by ICEM.
in CFX-pre it looks fine and inlet, outlet, wall configurations and interface between impeller and volute is set aswell.
But it doesnt complete any iteration under parallel processing and Double precision and only 13 iterations in series processing.
I have tried stator and frozen rotor both options in defining interface from impeller outlet to volute inlet.
I think i have set the physical models appropriately.
below is the error message am obtaining.
ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Overflow |
| Message: |
| Stopped in routine FPX: C_FPX_HANDLER |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| The following user files have been saved in the directory |
| D:\Xianghui_Cases\case_2_all_files\FlowRate_runs\d p_FrozenRotor\s- |
| etup_1_001: |
| mon |
| Warning! |
| After waiting for 60 seconds, 1 solver manager process(es) appear |
| not to have noticed that this run has ended. You may get errors |
| removing some files if they are still open in the solver manager. |
This run of the ANSYS CFX Solver has finished.
I have been stuck in this for almost a week and admire anyone with a little assistance.
Thanks.
residual is offline   Reply With Quote
Old   September 5, 2019, 04:08
Gert-Jan
Gert-Jan will become famous soon enough
It can be anything. Most likely your boundary conditions are not correct.
I would suggest to run serial, make a few backups during those 13 iterations, and see how it looks like in Post. Probably, you'll find the problem quite fast.
Regs Gert-Jan
Gert-Jan is offline   Reply With Quote
Old   September 5, 2019, 04:12
If you are getting a difference between serial and parallel then a partition boundary is in a bad place. Change the partitioning (maybe use recursive bisection) to move the partition boundaries away from the sensitive areas.
But if the serial run diverges with a floating point error then you have a problem with numerical stability. This is a FAQ: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ghorrocks is online now   Reply With Quote
Old   September 5, 2019, 06:24
Question
Upeka
Regs Gert-Jan
Thanks, I have specified this run under mass flow rate and inlet pressure.
I have tried more that 20 runs increasing and decreasing mass flow rate to very low and very high values. but it does not make any difference.
Old   September 5, 2019, 06:26
Question
Upeka
Thanks,
I have tried the first instruction. I ended up getting an error saying
*** INSUFFICIENT MEMORY ALLOCATED *** |
| ACTION REQUIRED : Increase the integer stack memory size.
And i have increased the stack memory upto 1.2. still i dont see any deviation from earlier warning
Old   September 5, 2019, 06:41
Gert-Jan
Are you convinced that the dimensions are correct? Sometimes users draw a geometry in meters and import in it mm, or the other way around.
And what do the back ups tell you?
Old   September 5, 2019, 07:11
Question
Upeka
Thanks for response,
Yeah i checked with the units and backups seems fine with what i understand.
cfx
CFX Solver does not write the results file and returns with error code 1 zeeshans CFX 17 November 16, 2023 12:11
The ANSYS CFX solver exited with return code 1. No results file has been created. kan8vicky@gmail.com CFX 4 April 26, 2016 03:10
Cfx results v/s experimental in radial turbine ameya.vjti CFX 5 March 20, 2016 09:36
Import results to CFX post MatjazR CFX 1 October 17, 2005 10:07
CFX cylinder or sphere benchmark results Mel CFX 1 August 8, 2005 19:47
