Visualising the interphase mass transfer rate in Post
Old   September 4, 2019, 16:34
Default Visualising the interphase mass transfer rate in Post
Gert-Jan
Gert-Jan will become famous soon enough
Hi All,
In an Eulerian setup I have an air and water phase with a component (e.g., CO2) transferring from air to water or the other way around, depending on the concentration differences. This works pretty well using Henry's law.
However, now I want to visualise the source term for this transfer, either positive or negative (the output file says I have both). But in Post this source term is not available, so I cannot visualise it in a straightforward way. Anyone knows an easy workaround?
Regards, Gert-Jan
Gert-Jan is offline   Reply With Quote
Old   September 4, 2019, 19:57
Sorry, I can't help you there. I can just suggest some guesses you might have already thought of - like defining a CEL variable which matches the CO2 transfer equation and then you can send it to an additional variable for post processing.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   September 5, 2019, 05:11
Gert-Jan
The stupid thing is that with Lagrangian setup, sources are available for postprocessing, but with Eulerian not. But Eulerian is preferred since it has Henry's law built in by default.
Probably I indeed have to built in Henry's law my self through CEL, allowing me to visualise the sources.
Interphase mass transfer of a reaction cfx_ws1992 Main CFD Forum 0 May 15, 2017 22:42
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Problem with total heat transfer rate aswathy_raghu FLUENT 0 July 26, 2016 08:39
How to Plot Mass Flow Rate vs Time Chart in CFX Post? michellemay1993 CFX 10 July 12, 2016 12:57
