how to do this turbine blade passage flow nanlysis
Old   January 12, 2006, 12:33
Default how to do this turbine blade passage flow nanlysis
manish
hi to all .I want to siumulate flow through bladepassage of a radial inflow gas turbine.It has presure drop of 2.8,so i have not to use stator.I have 12 no of blades.I am taking only one.It has w=1680 rad/sec (60,000 rpm).Inlet pressure is 2.83 bar (Total pr) outlet is 1.12 bar.Inlet total temp is 923 K and outlet temp is 760 K.mass flow rate is 0.596 kg/sec.Flow velocity at inlet 125 m/sec.I have given different boudary conditions but at each time it is giving very erronous results.i.e .pressure goes upto 9 bar.
(1) when i a m giving mass flow at inlet and pressuire at outlet then it is giving erromous resuts.mass flow is conserved but pressure values are far from actualk valus. (2) AT INLET Pressure and oulet pressure .Here pressure valuse have less difrence wit hactual values but mass flow is not mathich. can anybody guide me in this matters.whic hboundary condition i should give.and which initial valus i should give? . second thing is that can i go directly by giving unsteady anal;ysis .or first i have to solve this problem using steady satte and then go throgu hunsteady state. Thnks all.
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 15:07
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 03:33
[ANSYS Meshing] Mesh elements inside turbine blade eoinsturbine ANSYS Meshing & Geometry 2 May 15, 2011 12:44
Wind Turbine Blade Geometry SeanieB Main CFD Forum 0 November 27, 2009 11:18
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 3, 1999 00:18
