September 2, 2019, 13:47 |
Error detected by routine PEEKR,MAKDAT
Zhipeng Yao
Rep Power: 7 |
Dear friends
I simulated the bubble flow with polydispersed fluid method (DQMOM) in CFX19.0. The below error is appeared. I tried to increase 'Solver Memory Alloc Factor' to 1.5. But, it doesn't work. This seems to have other reasons. Could you please help me? Grateful for your help! +--------------------------------------------------------------------+ | Buoyancy Reference Information | +--------------------------------------------------------------------+ Domain Group: Default Domain Buoyancy has been activated. The absolute pressure will include hydrostatic pressure contribution, using the following reference coordinates: ( 5.00000E-02, 1.00000E+00, 1.00000E-02). Details of error:- ---------------- Error detected by routine PEEKR CDANAM = NOMSIZSCL/VALUE CRESLT = NONE Current Directory : /FLOW/PHYSICS/ZN1/MULTIFLUID_MODELS/MF1/SIZGRP +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ Details of error:- ---------------- Error detected by routine MAKDAT CDANAM = LVAR CDTYPE = INTR ISIZE = 361 CRESLT = OLD Current Directory : /FLOW/ALGORITHM/ZN1/SYSTEM/VARIABLES +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. |
September 2, 2019, 19:34 |
Rep Power: 144 |
This is not a memory error. CFX error messages can by very cryptic.
My guess is that you have not defined the size of one of your size groups in the DQMOM model. Check that all your size groups are properly defined.
How to make user routine just be called once in one time step? | doublestrong | CFX | 3 | October 22, 2018 00:06 |
calculate particle temperature gradient with user routine | amd18 | CFX | 1 | April 3, 2017 12:32 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
