September 1, 2019, 12:20 |
simulation used LES look like which used SST
Hi, I uesd LES model to simulate two condition, but the one of the result(Left of the image) look like that used SST model.
The configurations, mesh, model and boundary condition of two simulations are the same, expect the inlet velocity. Can someone tell me how to solver it? Thank you very much. https://i.loli.net/2019/09/01/r9JPY3fbsw1BFgI.png |
September 1, 2019, 19:58 |
Rep Power: 144 |
Have you checked your model that it has sufficiently low dissipation? Have you checked that you can accurately capture a turbulence energy spectrum?
If you want us to help you, you are going to have to explain what you are doing. Please attach the output file (or at least a snippet of it) and some images of what you are modelling.
September 2, 2019, 17:21 |
Gert-Jan
Rep Power: 28 |
The mesh.........
Is it setup for SST or LES? |
Specifying BC for LES simulation of pollutant dispersion problem in environment | jzuzul | OpenFOAM Running, Solving & CFD | 8 | June 21, 2018 08:21 |
LES simulation - Not able to bring down M value of every cell below 0.1 | shettysds | STAR-CCM+ | 1 | February 7, 2018 20:39 |
Validation of the accuracy of LES simulation | sidharath | Main CFD Forum | 7 | January 27, 2018 19:54 |
2D LES simulation of turbulent jet | adnan.nweilati | FLUENT | 0 | November 12, 2014 11:50 |
LES simulation of bluff body at Re(d)=1200 | arash_nl | FLUENT | 0 | June 1, 2009 14:16 |
