Simulation of liquid evaporation
Old   September 1, 2019, 02:44
Default Simulation of liquid evaporation
Onsh07 is on a distinguished road
There is a tank filled with helium. The tank wall is multilayered, composed of some solid domains.
Liquid hydrogen is supplied to the tank, and then hydrogen begins to evaporate when it contacts with the warm walls. When the tank is filled with liquid hydrogen, the supply stops and the tank is maintained for a certain time. The purpose of modeling is to make sure that the insulation is selected correctly, near-wall fluid layers do not boil during maintaining.
I use two fluids in the fluid domain: 1) helium (pure substation) 2) hydrogen (homogenous binary mixture), but I’ve received the following error:equilibrium phase in one phase in a multiphase run is not supported by the solver for this combination of thermodynamic states.
what multiphase model can you advise for this case?
Onsh07 is offline   Reply With Quote
Old   September 1, 2019, 08:16
Why do you need CFD for this? Why are empirical correlations and some hand calculations not sufficient?
Boiling simulations are difficult and even harder to get accurate. Getting it more accurate than a good hand calculation will probably be difficult.
But to answer your question - have you looked at the tutorial examples? I would also contact ANSYS support as they have additional examples and will probably have something close to your case.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Solid Liquid Simulation FLuent sandisk FLUENT 3 November 9, 2017 02:11
Liquid Fuel Combustion Simulation - need some guidance sa007057 FLUENT 0 September 15, 2014 14:57
CFX Liquid Evaporation Model Jinx CFX 3 January 28, 2010 17:31
evaporation on the surface of liquid nitrogen dodo FLUENT 0 March 3, 2008 05:37
evaporation from liquid surface to ullage? prasanth FLUENT 0 May 22, 2003 09:22
