Ansys CFX condensing flows
Old   August 27, 2019, 13:16
Default Ansys CFX condensing flows
Mahesh Chamarti
maheshchamarti is on a distinguished road
I am trying to model a condensing flow in Ansys CFX for a Radial inflow turbine with inlet guide vane and impeller. The expansion causes a 15% by wt liquid at the outlet. Iam having convergence issues by modelling the gas as a fictitious ideal gas by specifying CP,viscosity, molecular weight, conductivity and ref pressure and temperature.
The gas parameters are as follows
cpfld 11721.66 lbf*ft/slug*R
cvfld 8914.53 lbf*ft/slug*R
visc 2.735E-07 lbf*s/ft^2
conduct 5.355E-03 lbf/s*R
tinlet 436.98 R
pinlet 158414.40 psf
pstatic 86027.01 psf
mdot per vane 0.48317 slug/s
Can someone suggest the best way to model this gas ? Thank you.
Regards,
Mahesh
maheshchamarti is offline   Reply With Quote
Old   August 28, 2019, 03:20
Gert-Jan
Gert-Jan will become famous soon enough
Look for IAPWS or H2ORKvl materials
Gert-Jan is offline   Reply With Quote
Old   August 28, 2019, 11:54
Mahesh Chamarti
Hi Gert-Jan,
Thank you for your reply. Can you be more specific? The gas contains methane 94% and 6% ethane by wt. Thank you.
Old   August 28, 2019, 12:22
Gert-Jan
Sorry. I was preoccupied and thought you were talking about Steam.
In your case..........
The Ethane and part of the methane condensates? You should look for:
Materials -> Import Library Data -> import Wet Soave Relich Kwong
Then select CH4vl and C2H6vl
If you select these materials, you will model the gas and liquid as equilibrium. Then the interphase mass transfer is instantaneous. If you want to model non-equilibrium materials, you need to select the v and l materials separate and setup the mass transfer rates yourself, using Ranz Marshall or similar.
Good luck. You might need this.
ansys, cfx, gas model
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Orthotropic Properties in ANSYS CFX 14.5 (XY, YZ, XZ) lmark84l CFX 2 August 6, 2014 12:34
ANSYS CFX Tutorial Rashid CFX 25 December 20, 2012 02:22
CFX bought by Ansys - good or bad?! Pete CFX 38 February 21, 2003 08:34
