particle tracking
Old   January 5, 2006, 17:12
Default particle tracking
Gab
Hi, all
I am trying to do particle tracking to get a particle residence time distribution. The method I use is:
1. obtain steady state flow field 2.set particle input at inlet(CFX does not allow to set a point source for particles)
number of position=5000 [kg^-1] particle mass flow=0.01[kg s^-1]*step( (t-0.9[s])/1[s] )*step( (1.05[s]-t)/1[s])
3 do transient simulation(CFX10) using steady state solution as initial value, and time step is 1 s
The problem is that, at the montoring point, I got several peaks(particle number rate) at different timesteps . Each peak is very sharp and has same height. This is completely not reasonable
Can someone suggest how to get a residence time distribution curve using particle tracking?
Thanks!
Gab
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 01:59
massless particle tracking problem Renold FLUENT 0 January 26, 2011 15:23
Particle Tracking for ion Jun CFX 2 August 31, 2010 09:19
Number density tracking rather than particle tracking Rebecca Main CFD Forum 2 April 23, 2009 13:52
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
