How to set the transitional turbulence for blades
Old   January 2, 2006, 14:45
Default How to set the transitional turbulence for blades
Hermann
hi everyone, I am working on my graduate work and i need a little help.
I modeled a case for analysis of helicopter rotor blades coefficients such as Cp, Ct,Cl.I am using naca0012 airfoil for blades.
I create a fluid domain with general opts: air ideal gas, 1 atm of reference pressure, rotating motion with y axis.
fluid models: heat trans. mod.-> total energy turbulence model -> SST
Now, I want to know if I must have chosen any box in the advanced model control frame.
Moreover, how I set the transitional turbulence model.
I will be glad if who had any experiments with helicopter blades or master of cfd advices me.
happy new year
Old   January 4, 2006, 19:25
Default Re: How to set the transitional turbulence for bla
Andy
what have you set for your simulation type?
Old   January 4, 2006, 23:21
longbow
If you are using ANSYS CFX 10, transition model can be turned on at the place where you select SST model. In CFX 5.7, you have to use CCL to access this model. By the way, a special license key is needed.
Old   January 5, 2006, 15:06
Hermann
Hi Andy, I set steady-state for simulation and i am using CFX 5.7.1. Essentially I could run solver and then could adjust needed changes but i have nearly one million grid elements so that is very expensive for me.
regars
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 08:22
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Turbulence Properties set to on or off sven82 OpenFOAM Running, Solving & CFD 3 November 18, 2008 06:03
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 11:15
