January 1, 2006, 08:15 |
regarding back up
How back up file should be activetaed for transiet analysis?i.e. suppose i have stop the run now i want to retsrt it from whwre it has stopped by giving tha treult file as initial filoe.So i have to change my timestep and total time.so should i have to change total time and time steps. and yes then how it should be modified? Thank u.
January 3, 2006, 15:42 |
Re: regarding back up
You also need to change the default initial time to the time when you terminate the previous run. Regards! Jianping |
January 3, 2006, 22:39 |
No, you don't. You may use the option "Automatic with Value". When this option is selected, the values are obtained from the Initial Values File.
If you stop a run, you may restart it using the original .def Definition File and the .res or the (full_).trn file as the Initial Values File [list]Rui |
January 6, 2006, 10:01 |
thanx so whatever i ahve suggested is it right?i.e. i have to change total time and time steps?
Pressure outlet and back flow | eric | FLUENT | 11 | November 6, 2014 12:03 |
back pressure at exit for supersonic flow | BigFrank | FLUENT | 6 | April 24, 2014 16:13 |
Why back flow at the outlet??? | siddharameshwara | Main CFD Forum | 0 | February 9, 2011 06:07 |
exporting from Fluent back into Gambit | tom | FLUENT | 0 | June 23, 2008 17:55 |
Back up from Solver | selim | CFX | 1 | March 5, 2008 05:52 |
