CENTRIFUGAL FAN
Old   December 29, 2005, 08:18
Default CENTRIFUGAL FAN
mangesh
hi thanks
I AM GIVING TOTAL PRESSURE AT INLET AND MASS FLOW RATE AT OUTLET. BUT WHEN I CHANGE MASS FLOW RATE , TORQUE IS CHANGE ,
SO PLZ GUIDE ME FOR OUTLET BOUNDARY CONDITION.
Old   December 29, 2005, 11:55
Default Re: CENTRIFUGAL FAN
longbow
Why do you think torque should not change when you change mass flow rate?
Old   December 29, 2005, 23:39
Mangesh
HI
I AM TALKING ABOUT TORQUE OF FAN. I WANT TO KNOW EFFECT OF VARIOUS MASS FLOW WITH PRESSURE. WITH MAINTAING SAME TORQUE, AS WE ARE NOT CHANGING THE MOTOR..
GUIDE ME....
REGARD MANGESH
Old   December 30, 2005, 13:29
longbow
Do you change fan rotating speed? Bascially, if fan speed is not changed while mass flow rate is changed, fan will work at another point on fan curve. In this case, I don't know how you can maintain same torque. If you change both fan speed and mass flow rate, fan will jump to another fan curve. Then there is possbility that you can maintain same torque by adjusting fan rotating speed.
Old   January 30, 2006, 01:13
subbaramaiah
hi,
fan torque is proportional to (massflowrate * pressure rise across the machine). If above quantity increases then torque increases. please check your calculation.
Modeling of centrifugal fan in CFD Simon Williams Main CFD Forum 3 February 20, 2009 16:00
Multiple reference frame in centrifugal fan Peter Main CFD Forum 0 April 8, 2008 06:37
How to model flow of centrifugal fan? Peter Main CFD Forum 0 April 2, 2008 07:07
boundary condition for centrifugal fan vishal FLUENT 0 November 6, 2007 07:29
centrifugal pump and centrifugal fan Mangesh Main CFD Forum 3 January 3, 2006 12:21
