ERROR #001100279 has occurred in subroutine MESG_RETRIEVE
Old   August 7, 2019, 05:02
Default ERROR #001100279 has occurred in subroutine MESG_RETRIEVE
SEUL-GI LEE
SGlee is on a distinguished road
I have one problem about CFX-solver, the output file shows:
Parallel run: Received message from slave
Slave partition : 11
Slave routine : ErrAction
Master location : Message Handler
Message label : 001100279
Message follows below - :
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Overflow |
| Message: |
| Stopped in routine FPX: C_FPX_HANDLER |
| ERROR #001100279 has occurred in subroutine MESG_RETRIEVE. |
| Message: |
| Stopping the run due to error(s) reported above |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| The following user files have been saved in the directory |
| pids, trace, mon |
| Warning! |
| After waiting for 60 seconds, 1 solver manager process(es) appear |
| not to have noticed that this run has ended. You may get errors |
| removing some files if they are still open in the solver manager. |
This run of the ANSYS CFX Solver has finished.
I don't know 'MESC_RETRIEVE'
Who could help me solve this problem?
Many thanks in advance!
SGlee is offline   Reply With Quote
Old   August 7, 2019, 19:31
The only important error is the first one. All the other errors come about because the first error caused problems. The first error is a overflow floating point error, and that is a FAQ: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ERROR #001100279 has occurred in subroutine ErrAction. Sandeep Reddy CFX 3 May 22, 2019 19:58
Compiling User Fortran with CFX 14.0 on Win64 Raijin Thunderkeg CFX 29 March 9, 2016 12:45
"ERROR #001100279 has occurred in subroutine ErrAction ... no frame change model" darker2230 CFX 3 November 10, 2015 07:56
ERROR #002100004 has occurred in subroutine Out_Scales_Flu -> Reynolds-Number = 0??? thda7 CFX 2 June 21, 2014 06:53
ERROR #001100279 has occurred in subroutine ErrAct Carl CFX 2 July 16, 2005 15:39
