Error in the rotor-diffuser interface when grid is refined
Old   August 5, 2019, 07:09
Default Error in the rotor-diffuser interface when grid is refined
Overijssel
SSapkota is on a distinguished road
Hello everyone,
I have been encountering a problem. When I am doing simulation of a pump with a coarse mesh (cell size: 0.05 m) the simulation runs fine. There is an error warning that " Hard points are not supported and might be ignored in the 3D pre inflation " . I disregard this warning and it runs fine.
When I decrease the cell size to to 0.035 m, it gives me the same error warning plus error at the interface when i try to run the simulation. I had a similar error in the solver before but I reduced the impeller-volute domain interface tolerance to 1 mm and it worked fine. Now that I want to have a grid independent study, the solver does not let me.
The error is included in the attachment.
SSapkota is offline   Reply With Quote
Old   August 19, 2019, 16:13
M
AtoHM is on a distinguished road
Can you add an image of said interface?
AtoHM is offline   Reply With Quote
Old   August 19, 2019, 18:08
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Hello.
Have You tried suggestion from error message?
Maybe You should try to use GGI with "no intersection allowed" or/and use bitmap instead of direct approach.
Best regards,
Oskar
sheaker is offline   Reply With Quote
Old   August 19, 2019, 19:34
You should load the def file into CFD-Post and have a close look at the interface. There is probably something wrong with the interface elements, so have a look to find out what.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
How to use the CFX periodic interface zhihuawan CFX 61 January 15, 2018 17:20
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Radiation interface hinca CFX 15 January 26, 2014 18:11
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
"grid points" or "grid interface" ztdep Main CFD Forum 1 June 6, 2007 16:00
