Simulation time in CFX
Old   July 25, 2019, 08:59
Default Simulation time in CFX
Julian121 is on a distinguished road
I am running a transient simulation which has a total number of less than 2 m elements and 1.4 m nodes.
I am running it under local parallel processing.
I have tested 8-10-12-16 cores for 100 time steps. Each time step has 5-6 inner iterations.
It takes 150 min to complete 100 time steps under 16 cores.
It takes slightly more time if I use less cores.
I feel the simulation is too slow.
Is it normal for 100 time steps (500-600 iterations) to take 150 mins?
Julian121 is offline   Reply With Quote
Old   July 25, 2019, 09:15
Opaque will become famous soon enough
Slow/Fast are relative quantities respect to some reference
May I ask what is your baseline time for "normal speed"?
Then, given the reference, you must also compare settings. One iteration of a tough problem does not cost the same than a simpler problem keeping the same mesh.
One iteration at a large timestep does not the same as the same iteration with a smaller timestep.
Summary: it depends on the problem and the settings.
Opaque is offline   Reply With Quote
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
