July 24, 2019, 14:59 |
Error finding variable "TEMP_MT2"
Ivan
Rep Power: 7 |
Hi, everyone!
Could anybody explain where does the error come from, please? I am trying to simulate a gas metal arc welding process. I created geometry which consists of two domains separated by a common interface. One domain is defined as multiphase(steel and air) and the other one as a single phase (steel). The multiphase domain represents the formation of the molten droplets falling on the first side of the interface. The single-phase domain represents the flow of the solid metal, basically, it represents the plate. So, the multiphase domain is above the single phase. I switched off the option "constant domain physics" in order to have multi and single-phase domains respectively. I was thinking maybe that could be the problem, but I am not sure since I don't know the other option to make separate domains. Hope somebody could clarify this problem. Any tips, suggestions are very welcome. Thank you in advance. |
July 24, 2019, 15:30 |
Rep Power: 33 |
Do you have any expression that refers to Temperature?
July 24, 2019, 15:54 |
Ivan
Rep Power: 7 |
Well, yes. I have defined viscosity-temperature dependence in order to distinguish solid and liquid metal.
Secondly, I am using liquid metal which I defined in materials with reference temperature - Tmelting = 1733K., and thermal conductivity, which I defined in functions. and, for the molten droplets, I am assigning the expression, which basically says that they have the temperature 2500K and the rest of the multiphase domain is 300K as well as solid metal in the single phase. |
July 24, 2019, 16:12 |
Rep Power: 33 |
It seems the software is confused about which temperature to use in some expression.
If you can tell which phase the expression must be evaluated for, I would try something along MyPhase.Temperature in the expression. Then, the software does not have to guess which phase is implied for the expression. For single phase flows, there is no confusion, but for a domain with a multiphase model it can be a problem. Keep us posted, and good luck |
July 25, 2019, 13:15 |
Ivan
Rep Power: 7 |
Thank you for your advice!
I found my stupid mistake. All my expressions were defined with the Prefix "Stahl.T", with a capital "S". However, in the domain, in the basic settings, the material was defined as "stahl", small "s". It was not showing any conflict with that, so I was not able to notice this mistake. But when I finally changed the name of the material to "Stahl," the solver started to work. |
OpenFoam-1.6-ext Allwmake compilation error - one last barrier | Pat84 | OpenFOAM Installation | 15 | July 25, 2012 22:49 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 10:14 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 05:35 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 05:27 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
