"BADL" returned by User Fortran
Old   July 23, 2019, 06:51
Default "BADL" returned by User Fortran
Zhipeng Yao
Z.P. Yao is on a distinguished road
Hello!
I recently simulated the subcooled boiling flow in a vertical pipe with heated wall. With the influence of wall boiling, the near-wall flow field is different from adiabatic two-phase flow. It can be achieved by modifying the wall roughness to S=N*dw^3. So, I tried to correlate the roughness of heated wall with N(Nucleation Site Density) and dw(Bubble Departure Diameter) in User Fortran.
Howerver, the case does not work properly and send error message "BADL". According to modeling guide, it means "variable cannot be computed on the current LOCALE". I want to get the N and dw of each grid on the wall, but stuck by this problem. Has anyone encountered a similar problem?
User Fortran:
#include "cfx5ext.h"
dllexport(wall_rough)
SUBROUTINE WALL_ROUGH (
& NLOC,NRET,NARG,RET,ARGS,CRESLT,CZ,DZ,IZ,LZ,RZ )
C ------------------------------
#include "parallel_partitioning.h"
#include "cfd_memory_stacks.h"
#include "MMS.h"
#include "stack_point.h"
INTEGER NLOC,NARG,NRET
CHARACTER*(4) CRESLT
REAL ARGS(NLOC,NARG), RET(NLOC,NRET)
__stack_point__ pNSD,pBDD
C================================================= ======================
C Initialise RET(1:NLOC*NRET) to zero.
CALL SET_A_0( RET, NLOC*NRET )
C Get Nucleation Site Density
CALL USER_GETVAR('Liquid | Vapor.Nucleation Site Density',
& CRESLT,pNSD,CZ,DZ,IZ,LZ,RZ)
IF (CRESLT.NE. 'GOOD') GO TO 999
C Get Bubble Departure Diameter
CALL USER_GETVAR('Liquid | Vapor.Bubble Departure Diameter',
& CRESLT,pBDD,CZ,DZ,IZ,LZ,RZ)
C Calculate wall roughness by subroutine
CALL USER_WALL_ROUGH_CAL( RET(1,1),
& RZ(pNSD), RZ(pBDD), NLOC)
C Set success flag.
CRESLT = 'GOOD'
C
999 CONTINUE
C Send any diagnostics or stop requests via master processor
IF (CRESLT .NE. 'GOOD') THEN
CALL MESAGE( 'BUFF', 'UCF-WALL_ROUGH returned error:' )
CALL MESAGE( 'BUFF', CRESLT )
CALL MESAGE( 'BUFF-OUT', ' ' )
END IF
END
C
SUBROUTINE USER_WALL_ROUGH_CAL( WALLROUGH,
& NSD, BDD, NLOC)
C Purpose: WALLROUGH = NSD * BDD**3
C
C Inputs
INTEGER NLOC
REAL NSD(1,NLOC), BDD(1,NLOC)
C Outputs
REAL WALLROUGH(NLOC)
C Locals
INTEGER ILOC
C Function
DO ILOC = 1, NLOC
WALLROUGH(ILOC) = NSD(1,ILOC) * BDD(1,ILOC)**3
END DO
C
END
Out File:
| Average Scale Information |
Domain Name : Default Domain
Global Length = 5.5761E-02
Minimum Extent = 8.3138E-03
Maximum Extent = 3.6000E+00
Vapor.Density = 1.7251E+02
Vapor.Dynamic Viscosity = 1.6390E-05
Vapor.Velocity = 1.0000E-07
Vapor.Advection Time = 5.5761E+05
Vapor.Reynolds Number = 5.8690E-02
Vapor.Mass (Conservative) = 2.9908E-17
Vapor.Mass (Normalised) = 2.9908E-17
Vapor.Volume = 1.7337E-19
Vapor.Volume Fraction = 1.0000E-15
Liquid.Density = 1.0164E+03
Liquid.Dynamic Viscosity = 8.9400E-05
Liquid.Velocity = 1.0000E-07
Liquid.Advection Time = 5.5761E+05
Liquid.Reynolds Number = 6.3395E-02
| ERROR #002100004 has occurred in subroutine Out_Scales_Flu. |
| Message: |
| The Reynolds number is outside of the range expected based on the |
| Option selected for the TURBULENCE MODEL. Check this setting, |
| the values of the properties, mesh scale, consistency of units |
| and solution values in the input file. Execution will proceed. |
Liquid.Mass (Conservative) = 1.7622E-01
Liquid.Mass (Normalised) = 1.7622E-01
Liquid.Volume = 1.7337E-04
Liquid.Volume Fraction = 1.0000E+00
Liquid.Thermal Conductivity = 4.5700E-02
Liquid.Specific Heat Capacity at Constant Pressure = 1.4220E+03
Liquid.Prandtl Number = 2.7818E+00
Liquid | Vapor.Slip Reynolds Number = 1.3970E-11
UCF-WALL_ROUGH returned error: BADL
Error in subroutine get_TWFTFC :
Error calculating TWFTFC_FL1
GETVAR originally called by subroutine cal_CONVL_HTC
Thank you for reading, I hope for your help.
Z.P. Yao is offline   Reply With Quote
badl, user fortran, wall roughness
CFX User Fortran: Particle User Sources hustxinxin CFX 0 March 8, 2012 09:31
Particle Transport & Termination Control with User FORTRAN Julian K. CFX 3 January 12, 2012 10:48
Comparison between C/C++ and Fortran? rick Main CFD Forum 45 September 6, 2011 01:52
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
User Fortran and interior node information John CFX 0 August 26, 2008 23:24
