December 9, 2005, 12:18 |
How to switch of Timestepping Information
I have just installed CFX 10.0 and have run the same a transient simulation def.file as used before in v5.7.1 from scratch. An additional information appears now before each time step in the CFX-Solver Output File, telling me the "Timestepping Information" for the RMS Courant Number. I know this is needed for the Adaptive Time Step option which I, however, do not use. Does anybody know, if this RMS Courant Number calculation and the output in the output file can be switched off? Thanks Tobias |
December 11, 2005, 17:21 |
Re: How to switch of Timestepping Information
What is the point of turning it off? If you don't need the information then ignore it. Glenn Horrocks |
December 12, 2005, 03:57 |
Re: How to switch off Timestepping Information
Hello Glenn,
Thanks for replying. Well, this information did not appear in the older Versions (e.g. v5.7.1) and I am wondering, if this is now generally shown because of the additionally included time adaption option, or if this information only appears in the ouput file because of a mistake I've possibly made in my parameter settings. Regards TobiasZ |
December 12, 2005, 05:41 |
The information is there to help you! If you are conducting the transient simulation correctly, you should be satisfying the courant requirements for transient simulation even in CFX-5.7.1. At least this output saves you having to calculate the courant number manually or in CFX-post.
James |
December 12, 2005, 06:47 |
Understanding your comments correctly, the plot of the Courant number in the output file is now a fixed part in v10.0? If it's so, thanks for your help and advice. TobiasZ
December 12, 2005, 09:47 |
Yeah, its just a new feature which they have added. Before you had to calculate this manulally.
Representing controlDict information using OpenFOAM classes | sanatan | OpenFOAM Programming & Development | 4 | February 28, 2012 07:46 |
interchanging face information with cell information/ radiation flux UDF | ximik | FLUENT | 1 | May 4, 2011 17:34 |
information from saved data files:Unsteady flow | Atul | FLUENT | 5 | July 27, 2008 21:05 |
Information - SES | Giovanni | Main CFD Forum | 0 | March 2, 2004 14:17 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
