Pressure jump too late in (laminar, turbulence free) convergent-divergent nozzle |
July 19, 2019, 13:59 |
Simon
Rep Power: 7 |
Hello Guys,
sorry for any mistakes, this is my first post. For University I am trying to model a convergent-divergent nozzle with CFX (quasi 2D ICEM CFD Mesh). For now I just want to simulate it without viscous Forces and laminar, turbulence free flow. My boundary conditions are p_exit = 0.7bar (static pressure at outlet), p_0 = 1bar (total pressure at inlet). I assume Air ideal Gas (kappa=1.4, T_0 = 300K). The crosssections are 51mm^2 at inlet, 24mm^2 at minimal crosssection and 42.28mm^2 at Outlet. From these I calculated the pressure drop to be at the crosssection with approx. 28.5mm^2 (see attached file "calculate_shock"). But when simulating with CFX, the shock occurs further downstream at approx. 35mm^2. (Arrow shows location where it should be) For the simulation I used free-slip walls and symmetry conditions at the sides. Turbulence model is none. I use Total Energy Equations without viscous terms. Has somebody a hint what I might have missed? Or what further information do you need? Best Regards Simser |
July 19, 2019, 21:50 |
Rep Power: 144 |
Before comparing your results to anything you need to check your simulation is accurate. Comparing an inaccurate simulation to anything is pointless. This FAQ has some explanation: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
With the key bits being you need to check your convergence criteria is tight enough and your mesh fine enough.
July 20, 2019, 06:15 |
Simon
Rep Power: 7 |
Thank you for your answer, I already looked through these guidelines. I startet with coarse meshs and refined them stepwise until cells with 0.25mm width globally and then refined the location of the pressure drops further. I got max. Residuals under 10^-5 and the pressure drop was always at the same position.
But a colleague informed me today that I had a wrong assumption in my theoretical calculations and now both Simulation and Theory correlate well. |
convergent-divergent, laminar flow, laval, laval nozzle, turbulence free |
Supersonic free jets from CD nozzle | naveensdas | FLUENT | 14 | May 2, 2013 13:07 |
Pressure jump and momentum source | Tanya | FLUENT | 1 | June 4, 2009 16:22 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 10:52 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
