residence time distribution
Old   December 6, 2005, 03:49
Default residence time distribution
markus
Hi... I want to use a Particle Tracking approach to obtain the RTD of a vessel based on a steady state simulation. When doing this the mean residence time gets way to high. I used small particles with a density of 1 and added turbulent dispersion. I am not sure about adding additional forces.
Any hints to the problem or another suggestions on how to obtain a "lagrangian" residence time distribution?
Old   December 6, 2005, 09:58
Default Re: residence time distribution
Martin
it it much easier to implement an Additional Variable "RDT" with unit [s] and transport equation. RDT is set "0" at all inlet.
Then you create a subdomain "RDT sub" over all and impement a source for RTD with 1 [s/s]. Now RDT will become greater with resident time.
bye martin
Old   December 6, 2005, 10:46
markus
I aready tried the implementation of an additional Variable RTD. Analysing the spatial distribution of RTD at the outlet of my reactor gives the right mean residence time, but just a rough approximation of the distribution (too coarse grid??) and a too narrow distribution (probably due to numerical diffusion effects). That why this approach seems not very powerful to me.
markus
Old   December 8, 2005, 02:47
Martin
your particle tracking can't be better than your grid - so this would be the problem with your results. Diffusion effects shouldn't be if you use ADVECTION SCHEME: high res
Old   December 19, 2005, 06:52
zhixin huang
Hi... How to get residence time distribution in cfx-post? thanks.
Old   December 19, 2005, 12:48
markus
I'd run a transient simulation with a frozen flowfield where you solve a transport equation for an additional variable (scalar). Use pulse or step input and then monitor the massflow average of this quantity over time at the outlet.
markus
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
Pathline colored by time = residence time pkleb FLUENT 1 February 26, 2021 09:00
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
How to get residence time distribution? bigfans FLUENT 0 April 27, 2009 10:39
Residence Time Distribution rajeev FLUENT 11 July 26, 2001 14:49
