Convergence Problem Supersonic Flow Laval Nozzle
Old   December 5, 2005, 11:55
Default Convergence Problem Supersonic Flow Laval Nozzle
Tobias
Hello I simulate a Laval Nozzle. The nozzle is part of a real wind channel and the part which creates supersonic flow at the outlet (Ma >2.0). I use subsonic pressure inlet (total pressure, total temperature) and supersonic outlet. Two Problems occur, maybe somebody got some advices (solution strategies) for me:
First, overall massflow is too small (no shock occurs!!)
If I choose massflow inlet, solution crashs because of to big mach number.
Thanks to you, Tobias.
Old   December 6, 2005, 07:21
Default Re: Convergence Problem Supersonic Flow Laval Nozz
Bart Prast
1. Use the expert parameter: max continuity loops = 2 (you should always do this for supersonic flows) 2. Do not start up with a supersonic outlet as it will not be a supersonic outlet when you start the calculation. Start first with a pressure boundary untill you have supersonic conditions at the outlet (then switch over)
Old   December 6, 2005, 07:24
Bart Prast
I forgot:
How can you use a supersonic outlet condition when you expect a shock????? The flow will be subsonic after the shock and at the exit of your nozzle.
Old   December 7, 2005, 02:23
tobias
Thanks for your advices Bart, I'll try them. I studied the modelling guide and suggest now the same way how to solve this porblem.
By definition of a supersonic outlet I supposed CFX to find the solution without the present of a shock, but I failed. If it works, I'll report.
Thaks to you, tobias.
Compressible de Laval Nozzle Flow rw511 CFX 3 May 22, 2011 20:48
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 12:46
convergence problem with compressible flow S.B.J. Siemens 2 February 2, 2009 05:05
Convergence problem with compressible flow S.B.J. Siemens 2 January 7, 2009 04:29
Convergence problem in SUPERSONIC FLOW sridhar FLUENT 0 July 7, 2007 12:16
