CFX 5 Domain Interfaces
Old   December 4, 2005, 16:19
Default CFX 5 Domain Interfaces
Chris
I am trying to model something involving both a hydrocarbon gas and air. I made my first domain the gas and the second air. When trying to create a domain interface I get multiple error messages. How do I do this properly? Do I make the air inlets openings in the first domain or leave them as part of the default? Any help would be appreciated.
Old   December 4, 2005, 22:39
Default Re: CFX 5 Domain Interfaces
rajit
I reckon that will hav no effect.Your interface will be fluid-fluid interface.I cannot give you more suggestions unless you let us know what error messages you get.
Thanks Rajit
Old   December 5, 2005, 04:50
Chirag Jayswal
I guess, you must have defined two different fluids for two different domains. That creates errors.
As solution to this, you need to define a common variable component mixture in material section that contains both your fluids, air & HC.
Use that mixture as fluid for both domains. For air domain make mass / volume fraction air equal to one & the same of HC equal to zero. Similarly, for HC domain make mass / volume fraction air equal to zero & the same of HC equal to one.
This may solve errors those you are getting.
Hope this helps.
How to: Domain Interfaces Neusier CFX 8 March 22, 2011 07:34
ERROR #001100279 All nodes in the domain named XYZ are on interfaces. peterputer1 CFX 2 October 8, 2009 08:56
Multiple domain interfaces on a single surface mike CFX 2 January 26, 2009 18:03
CFX Fluid Domain Movement greg CFX 1 March 25, 2007 09:08
Cancel a domain in CFX solver Neser25 CFX 2 February 19, 2007 12:19
