expert parameters of SST model?
Old   December 1, 2005, 21:20
Default expert parameters of SST model?
David
Hi, all
The SST model employs many model parameters that could be changed through "Andvanced Model control" panel. It seems that CFX documentation has not provided enough explaining and guide of how to determine this parameters. The default values of these parameters might be not suitable for specific flow simulation, and it had been validated in my case when the standard k-e model employed.
So I want to ask: anyone could provide some explaining or where could find the detailed messsage of SST model? thanks
Old   December 2, 2005, 07:36
Default Re: expert parameters of SST model?
Adam
I think the reason why they haven't included much information about the expert parameters is so that you have to really know your turbulence modelling to know how to use them correctly. Unless you know exactly what you're doing, it's probably unwise to touch them.
Unfortunately, it means a lot of reading etc
Adam
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
SST model swe704 Main CFD Forum 0 February 5, 2010 09:36
YPlus Values and SST Model Jenny CFX 1 June 22, 2008 19:47
Convergence issue in SST for Porous model Raj CFX 0 May 2, 2008 03:43
wall roughness with SST turbulence model in CFX10 Vincent CFX 7 September 10, 2007 17:49
