Time value of timestep in Transient simulations
Old   November 30, 2005, 13:15
Default Time value of timestep in Transient simulations
siv
Hi all, I need to plot CH4 concentration at outlet against time value in transient simulation. In CFX-chart i am not able to select locator. Can any one help me how to do this? How can we get Time value for each time step. In the documentation they explained only about time steps. Thank you.
Old   November 30, 2005, 13:43
Default Re: Time value of timestep in Transient simulation
Rui
In Post, you can create an expression like areaAve(CH4 concentration)@outlet, and create a Chart (Chart tab: Type=Time ; Chart Line tab: Method=Expression)With this method you'll get the value of the expression just at the time instants when you have .trn files (this may be or not enough)
If you create a Monitor Point (in Pre), in Solver you'll get the expression value at every time-step
Old   December 2, 2005, 06:26
siv
Hi Rui, Thank you. Its working in this way. I have one more question- Generally how can we get time value of each time step like any other variable(for eg. i could get velocity value for each time step using power syntax but couldnīt get time value). If you have any idea please let me know. Regards, Siv
Old   December 8, 2005, 12:15
Tobias
if you use charts in Post, then you can plot any value against the time, but not against time steps as far as I know. This is when you select 'time' in chart>type.
Regards
Tobias
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
How are a transient simulations performed?? Luk Main CFD Forum 0 October 19, 2007 11:09
